Wooden Basement Post Rotten On Bottom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2008, 12:00 AM   #1
wooden basement post rotten on bottom
After I am gone for an extended period of time and walk into my house there is always one fairly loud pop when I walk across the dining room. The above mentioned post is under this area. It is just sitting on top of the floor but where it meets the floor is rotten. A good kick proves that it is not holding anything up. Also I suspect that this is also the reason that I have cracks in my dining room wall too.
Can I replace that post with a metal "jack" or should I go with wood again.
The house is an American Foursquare built circa 1907.
Thanks for any insight.
truckinkat is offline   Reply With Quote
Old 09-29-2008, 05:35 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
The metal column would be fine to use. but if the post is holding a great deal of load above it will be wise to install some type of concrete pad under the post level with the floor.( if there is not one there now)
Replacing window sash with rotten bottom jandrew Carpentry 3 08-31-2008 04:02 PM
Leak into basement at bottom of Door deepstuff Building & Construction 8 08-19-2008 01:46 PM
Old wooden supports in basement of 2 family 100+ year old house ytorrie Building & Construction 2 06-03-2008 06:31 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 07:55 AM
