wooden balcony in living room
I want to build a wooden balcony in my living room. The height of the room is about 9 feet, while I intend to have the balcony at about 6 feet. The length of the room is about 12 feet and the depth of the balcony will be about 3 feet. My problem is that I don't want any columns along the beam that will span the room. Would that be possible? Could I put some posts to support the beam at each end and bolt them to the concrete block walls at either end? What size beam would I have to use? The maximum weight that will be on this balcony will be about 200 lbs.
Are You Building A Large Shelf ??
Just to check I understand what you're proposing...
Your living room ceiling is 9 ft high. You want to build a balcony in your living room at a height of 6 ft. Are you on drugs?? You are basically proposing a large shelf. Get a grip on reality!! |
| All times are GMT -4. The time now is 01:01 AM. |
