Woodburner To Fireplace Conversion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2007, 12:15 PM   #1
Ron
Woodburner to Fireplace Conversion
Hey Guys, I have a woodburner stove, which I would like to replace with a wood burning fireplace. My question is: can I use the present chimney and can I center the fireplace on the wall, which would mean having a flue at an angle?? (See attached pictures). The chimney has 9X13 ceramic flue and brick exterior. Presently, the woodburner flue enters the wall 44" from the right corner, on a 65" wide wall. I would like to center the fireplace on this 65" wall instead. This would mean an angled flue (I guess?) Would the flue be large enough? Or can you install a stainless steel liner inside the ceramic??
Having trouble attaching picture. Will edit and attach later.
Ron is offline   Reply With Quote
Old 08-16-2007, 10:01 PM   #2
Eibwen
I would stick with the stove! Its a lot more energy efficient than a fireplace.
Sammy is offline   Reply With Quote
Old 08-17-2007, 10:36 AM   #3
Ron
Question
Thanks for the advice Sammy, but I knew that already. What I'm trying to do is free up some space in my family room and also I think a fireplace looks much better. Not really worried too much about the efficiency as I personally don't use the woodburner that much anyway. I'm going to be selling this house in about 5 to 7 years, so I'm trying to make it a little more appealing to the masses.But thanks again. Lots of people don't realize the truth about fireplaces. Just wish some of you masons out there would chime in and give me a hint if this is doable or not. I realize there are lots of other questions you might have, so let's have 'em!
Old 08-17-2007, 11:25 AM   #4
Rewards Points: 264
That would be nice. I use my fireplace pretty much every night, weather permitting. Even in the fall with all the windows open.
Good luck!
Jeekinz is offline   Reply With Quote
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
Gas Fireplace ChrisSensabaugh HVAC 3 07-31-2007 07:08 PM
huge fireplace issues krynstar Painting 10 03-10-2007 07:41 PM
Fireplace leaking mmcginn2 Roofing/Siding 4 04-23-2006 11:12 AM
Water leaking over fireplace mmcginn2 General DIY Discussions 1 04-21-2006 12:42 AM
