Wood Vs Steel I-beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2010, 06:57 AM   #1
wood vs steel I-beam
I bought an early 1900 cottage style 2 floor house. In the basement the joists are sagging and I just want to add some support for the joists. There is not a lot of head room. On each side of the stairway, which splits the basement in half, I have a 9 foot span. Right now there are 3 2x6's nailed together for a beam on lolly columns in that 9 foot span across the joists. It is still sagging a little.
My question is - would a 4" x 4 1/8" steel I beam be stronger than the 3 nailed together 2x6's?
newfeet1 is offline   Reply With Quote
Old 05-25-2010, 08:54 AM   #2
The area moment of inertia for the steel is ~1/10th that of the wood and the E is ~18x, so steel is only ~1.8x stiffer.
This is pretty close so more info on the I beam and the wood grade/type is needed.
Old 05-25-2010, 12:16 PM   #3
Civil Engineer
Rewards Points: 4,706
Steel beams are not listed in the format you described, which I assume is depth x width. The closest shape I have in my tables is a W4x13, which is 3.83 inches deep x 4.16 inches wide, with a moment of inertia about the XX axis of 11.3 in^4.
As mentioned by Yoyzit, the relative stiffness of the beam is a function of the modulus of elasticity of the steel, which is approximately 29 million, versus about 1.8 million for wood (depends on species). The relative STRENGTH of a steel I beam versus wood is a function of the yield strength of the steel, which is typically a minimum of 36 million psi for structural steel, but may also be 60 million psi.
So to determine if the I beam has greater or lesser capacity than the wood, you need to know the yield strength of the wood, the exact dimensions of the wood, and the yield strength of the steel.
All that said, are you sure you even want to consider replacing existing joists that are sagging with steel? That would be a large job, and unless there is a real structural problem, may be an unncessary expense.
Daniel Holzman is online now   Reply With Quote
Old 05-25-2010, 12:21 PM   #4
daniel i think just the 2x6 beam is in the mix
The older I get the better I was
Old 05-25-2010, 02:13 PM   #5
in such a small application wouldn't an engineered wood product be better / less expensive? assuming that the existing structure is indeed replaced that is.
i hated taking structures...
cellophane is offline   Reply With Quote
Old 05-27-2010, 10:46 AM   #6
I am not replacing the joists. This is just for extra support. The previous owner only had a 4x4 pine beam. I just wanted to know if the steel I-beam (which Daniel clarified the size) would be stronger than the (one) beam I made up of 3 2x6's nailed together. By the way, thank you everyone for helping out with all this info.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Basement beam cut in half and steel plated 107 Building & Construction 2 12-19-2009 07:24 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
Wood Beam dhatley4 Building & Construction 1 11-03-2008 01:09 PM
steel beam length otto man Building & Construction 4 07-27-2008 08:11 AM
