Old 06-11-2012, 05:39 PM   #1
wood vs steel
In your experience, is wood framing more or less expensive than steel?
To qualify it a bit, say a 14 x 20, slab on grade, one room, typical drywall interior and vinyl siding exterior.
7echo is offline   Reply With Quote
Old 06-11-2012, 05:55 PM   #2
concretemasonry's Avatar
wood vs steel
Since it all just about price. Get bids for each methos of construction.
If other factors such as resale, insulation and sound make the question more challenging.
Is this a free-standing room or is it a attached? Building out of the same materials is usually best.
Dick
concretemasonry is offline   Reply With Quote
Old 06-11-2012, 06:12 PM   #3
wood vs steel
Free standing.
It will be insulated. Built to be a detached room, maybe for a studio, or office, or MIL suite.
It isn't all about budget, more like inexpensive quality...
So, can you build cheaper, I mean less expensive, with steel studs or wood studs for this sort of application?
Old 06-12-2012, 01:16 AM   #4
Moderator
wood vs steel
Price them out locally.
As Dick mentioned insulation......... steel studs are a big thermal link to exterior temperatures with inherent convective loops and possible "ghosting" with f.g. batts: http://www.buildingscience.com/docum...rm=steel+studs
http://www2.dupont.com/Tyvek_Weather...20Bulletin.pdf
Gary
Clothes taking longer to dry?
Old 06-12-2012, 08:27 AM   #5
wood vs steel
Reading on Building Science shows that wood, using Advanced Framing, is a good option. I am going to look more into that.
Mostly I see they have a vapor barrier between the drywall and studs. Is that for a climate where heating is the main focus of HVAC? Where I am the environment is hot, humid summers and mild winters. Last winter the cat water only froze one time.
Old 06-12-2012, 09:14 AM   #6
wood vs steel
OK, I found the DOE site that says we are in zone 2. Zone 2 building says no vapor barrier on the interior of the wall assembly.
Old 06-12-2012, 09:50 AM   #7
AHH, SPANS!!!
wood vs steel
I would think that wood framing would be best. all of the tradesmen will most likely know how to attach things and drill through wood and what not. you would need a commercial crew to come do your residential work, or is this going to be a commercial structure?
hand drive is offline   Reply With Quote
Old 06-12-2012, 09:52 AM   #8
AHH, SPANS!!!
wood vs steel
you want to have tyvek type wrap as the vapor barrier installed on the outside of sheathing
Old 06-12-2012, 08:19 PM   #9
wood vs steel
I will probably do most of the work, especially if I go with wood. And, it looks like that is the best option all things considered.
Thanks for the comments.
wood vs steel I-beam newfeet1 Building & Construction 5 05-27-2010 11:46 AM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General Discussion 0 05-22-2010 02:31 AM
steel vs wood garage doors rocketdoctor Building & Construction 10 09-17-2009 06:35 PM
Exterior door type - wood, steel, etc hellothere123 Building & Construction 15 08-13-2009 09:39 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
