Wood Stove Backing Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 08:05 AM   #1
Newly Retired
tuchodi's Avatar
I am moving my wood stove which we use to heat our house to a more central location. It will be in a corner on inside walls. We are going to put Ledgerock Stone behind it for protection. Would you use regular drywall as backing or a cement board?
tuchodi is offline   Reply With Quote
Old 06-30-2011, 09:20 AM   #2
DIY staff
Rewards Points: 7,174
I'd want 5/8 inch fire rated drywall or 5/8" Durrock---Just a little added insurance.
Old 06-30-2011, 07:53 PM   #3
use the durarock, drywall is considered flammable, because of the paper surface - fire-rated drywall simply holds the fire back a little longer - it'll burn too.
If you really want to go the extra 5 miles for safety, stand the durarock off of the wall with hat channel for a vented air space behind it.
OffRoadAudio is offline   Reply With Quote
Old 06-30-2011, 07:56 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Cement board won't burn and would be a much better bonding surface for the stone application.
XXX
Old 07-01-2011, 01:06 AM   #5
Newly Retired
tuchodi's Avatar
Thanks guy's I am going down and pick up the cement board tomorrow.
Wood Stove in Basement? dwolek HVAC 4 10-28-2009 08:02 AM
Wood stove grate? econdave General DIY Discussions 1 01-06-2009 02:19 PM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Wood stove ? econdave General DIY Discussions 8 10-17-2007 06:50 PM
