Old 10-13-2011, 06:36 PM   #1
Wood Stair Treads Set in Mortar
I'm working on a set of 30 yo stairs previously covered in carpet.
The rough stairs are not level from riser to nose; about 1/2" off.
The new stair treads will be bullnose hard maple.
I'd like to consider using a mortar bed to both level and attach the treads.
Has anyone sen this technique work?
kennardn is offline   Reply With Quote
Old 10-13-2011, 06:42 PM   #2
Moderator
kwikfishron's Avatar
Not a good idea…just cut some shims.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 10-13-2011, 06:46 PM   #3
concretemasonry's Avatar
Absolutely!!!. Shims are the best way to go.
Dick
concretemasonry is offline   Reply With Quote
Old 10-13-2011, 09:10 PM   #4
Great, thanks.
Old 10-13-2011, 11:36 PM   #5
What kind of staircase are you talking about?
What are you trying to do?
Are you replacing treads in an interior staircase?
Open or closed stringers?
Are you placing new treads over the old treads?
For the life of me, I can't figure how you would use a mortar bed in any scenario of a wood staircase.
And the only scenario with wood shims is with an open stringer staircase.
Ron
B. Franklin 1759
Tags
mortar, stairs, wood
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
New stair treads and flooring rickkeeter Flooring 2 02-24-2010 11:16 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Stair Treads Melanie337 Flooring 1 04-02-2008 12:22 AM
