Wood Siding Removal With Lead - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 02:26 PM   #1
Wood Siding Removal with Lead
I'm considering purchasing a house in VT (built in the 60's) for a primary residence. I am going to remove the siding for various reasons, however there is a good chance that the wood has lead paint. Based on the pure volume of data, its hard to get a good answer on the best way to dispose of the wood that comes down. I have no problems putting down the proper plastic protection on the ground, removing chips safely etc. I plan to do this work myself, I do not plan to hire a contractor, I do not plan to rent the property.
The question is, how do I dispose of the wood that has lead paint on it?
Not finding a clear answer.
Thanks!
mrvt is offline   Reply With Quote
Old 01-16-2011, 03:36 PM   #2
Rewards Points: 6,652
Have you already sent a sample to a lab to test for Lead? As for your question, if the building has Lead paint, it would have to be disposed & handled as stated in your state's EPA guidelines for Lead paint. That means $$$, so how deep is your wallet.
Old 01-16-2011, 04:46 PM   #3
No, I havent sent anything at this point. I had heard that if it was done w/o a contractor and done for a primary residence it could be removed by the myself. The short answer like most today, my pockets are not very deep. Assuming that the wood siding ends up in a pile (properly wrapped) what experience has there been disposing of it?
You would think there would be a incentive to try and get rid of it properly rather than making it more complicated or by simply covering it and ignoring it as if it doesnt exist, and leaving liabilties out there for owners...
Any other cost effective solutions other than covering it up, not buying, or paying too much?
Old 01-16-2011, 05:07 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,... A campfire....
Save the food for the gas grill...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
mrvt (02-23-2011)
How to repair vertical wood siding? darsunt Building & Construction 1 11-19-2009 06:46 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
