Wood Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 02:55 PM   #1
wood siding
my house is clad with rough cut pine siding which is stained. One side faces south and we have to restain it every year. Any suggestions? Should I replace with cedar? Would that hold the stain any better?
carolenm is offline   Reply With Quote
Old 05-27-2011, 04:05 PM   #2
Rewards Points: 1,092
Are you using a UV resistant stain? I used a UV resistant log oil (light pigmentation) many years ago, and after a couple more applications (every few years) it looks like it is a done deal. I think it was Moose Hide. Can you live w/ an opaque one? Consumer Reports recently rated stains, transparent to opaque; that may be worth a look.
Old 05-27-2011, 04:17 PM   #3
kwikfishron's Avatar
Rewards Points: 586
If the siding itself is in good condition (no rot) then I wouldn’t replace it. The problem is more than likely the product your using for stain than the pine itself.
Have you looked at any of the Sikkens products for stain?
kwikfishron is offline   Reply With Quote
Old 05-28-2011, 09:03 AM   #4
Thanks for the quick replies. Yes, I have used a stain with UV protection. The wood has been "over" pressure washed and is fuzzy. I will look into the Sikkens, I have heard good things about it...
Mixture of Siding Material (Vinyl and Wood) jburr827 Building & Construction 2 05-19-2011 08:38 AM
Vinyl siding over wood travem Remodeling 6 02-06-2011 10:32 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
