Old 07-29-2010, 05:46 AM   #1
Wood Shed Racked
What are typical causes for a shed that racks and what are the noticeable supporting elements of proof?
Shed is on a stone pad and not yet 3 years old. One door appeared to be warping (RHS). When we put a framing square on rhs door opening corner we detected that the opening was out of square by 3/8".
db54 is offline   Reply With Quote
Old 07-29-2010, 06:52 AM   #2
Wood Shed Racked
If the perimeter support is not below the frost line, it will not be stable, and whatever sits on it will also move. That is where i would look for the solution to the problem.
Old 07-29-2010, 03:08 PM   #3
Wood Shed Racked
Someone put the shed on an inadequate base. The proof is that it's racking.
Ron
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 12:35 PM
water run off in shed kathy k Building & Construction 4 08-09-2009 04:29 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
expanding existing concrete pad for shed lz300 Building & Construction 1 04-06-2008 09:20 PM
