Wood Rot - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2008, 09:44 AM   #1
Rewards Points: 154
Wood rot
Rain water has been dribbling down this corner of my entryway for 25 years. When I finally opened it up I could see the guys who put it together were unfamilar with the concept of flashing. The adjacent studs and siding have held the structure firm with no cracking or settling. I had a similar problem at another corner of the house where I sawsalled out what I could, inserted blocks of new lumber with plenty of bondo, flashed and replaced the siding. What would you more experienced do short of a major reconstruction?
Wood rot-img_3038.jpg   Wood rot-img_3016.jpg   Wood rot-img_3018.jpg   Wood rot-img_3040.jpg
ovahimba is offline   Reply With Quote
Old 07-28-2008, 10:15 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I would remove the rotted sill plates. the studs seem to be fine. I don't know of the ones on the garage sidewall under the decking that was removed. I would be especially concerned about the garage door header and jacks compressing them over time. putting the roof and door out of level. BOB
Old 07-28-2008, 04:20 PM   #3
Registered User
Termite's Avatar
Flashing the ends of the deck boards is basically impossible. I wouldn't put it back the way it is.
What I'd do is....Once the house's structure is repaired with new wood....I'd re-configure the joist framing and run them side to side instead of front to back. That way your deck boards can run front to back, and the one against the house can be a 2x2 strip with some flasing over it. The deck ledger would attach to the house and would either be flashed correctly or spaced off the siding a little bit.
Old 07-29-2008, 09:38 AM   #4
Rewards Points: 154
Thanks for the feed back. I just installed some temporary decking for my wife's party and I'll address the rot later but before the rains come which might be a while as I'm in dry California.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
