Wood I-Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2008, 11:35 AM   #1
Git
Wood I-Joists
Hello
My house is five years old and is built using wood I-Joists, similar to the picture below. (They are actually a Boise Cascade BCI 450 joists and I believe the flange is 1.5" wide)
I wanted to hang some shelves and a storage device called a Racorpro Heavylift (see pic) from the ceiling in my garage.
The frame for the heavylift is approx 48" x 48" and is desinged to be bolted to ceiling joists that are 16" on center. My I-Joists appear to be 19.2" on center, so I planned on running two 60" long, 2x4's across three of the joists and then centering the frame on the 2x4.
How would I properly fasten the 2x4 to the bottom of these I-Joists? The ceiling is drywalled with 5/8" and I planned on cutting out little squares at the attachment points so I could properly locate the joist. They would later be covered by the 2x4.
Any help would be appreciated, thanks
Git is offline   Reply With Quote
Old 03-18-2008, 09:55 AM   #2
Git
Anyone?
Old 03-18-2008, 04:42 PM   #3
CT Builder
Once you get the locations of the Joists, Fasten the 2x4's using 3" drywall screws in a predrilled holes. Apply some liquid nails prior to fastening for an extra hold.
-Daryl
Daryl is offline   Reply With Quote
Old 03-18-2008, 05:23 PM   #4
Spanning three joists is just fine.
raam is offline   Reply With Quote
Old 03-18-2008, 07:57 PM   #5
From what I've seen, most manufacturers won't let you cut or modify the flange at all. You might be better off furring out the web with blocking and securing your 2x4 framing to that.
ncgrogan is offline   Reply With Quote
Old 03-18-2008, 08:29 PM   #6
remodeling pro
I think he is referring to cutting out little squares of the drywall, not any of the joist. Even rather than that, why not use a nail to locate both edges of the flange, then just measure? The line of nail holes will be covered by the 2 x 4.
Better than drywall screws, use some cabinet hanging screws with the large washer heads.
troubleseeker is offline   Reply With Quote
Old 03-19-2008, 08:35 AM   #7
CT Builder
to cabinet screws
-Daryl
Old 03-19-2008, 11:58 PM   #8
Rewards Points: 150
I would'nt cut the rock that's your firebreak, especially to mount the 2x4 directly to the joist. If god forbid there was a fire you are creating a wick for the fire to spread up to the joist. I would screw the 2x4 right to the rock rather than compromise your fire rating. That type of storage device is pulling down on the mounting area, Not compressing the sheetrock.
James Con is offline   Reply With Quote
Should I paint the Crawl Space Wood Joists? They are exposed? twilightcall Painting 11 09-21-2009 08:46 AM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
