Wood For Foundation. R.S.K. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2012, 04:48 PM   #1
wood for foundation. R.S.K.
what kind of wood and treating should it be, partially in the ground. It's a foundation.
grkeenan is offline   Reply With Quote
Old 10-17-2012, 05:29 PM   #2
Rewards Points: 13,296
Is this something your going to build or something in place already?
I'd never in a million years suggest anyone have any wood in contact with the earth.
Yes it's been done, just no way I can see it holding up over the long term.
Old 10-17-2012, 05:34 PM   #3
Rewards Points: 372
Here's a link with about everything you might want to know:
http://www.apawood.org/level_b.cfm?content=app_rfl_cs_about
My Son in Law is installing a foundation right now for his new home. He rented a bobcat and drilled each hole 48" deep, and is planning a 30" crawlspace.
He is using treated lumber of course, and to add life to the uprights he is coating each one with raw tar sealant on the bottom part up to 4" above ground level before setting them in place. Pay extra attention to the very bottom of the post as that is where rot can start. UPDATE: I forgot to mention he's pouring about 12" - 15" of concrete into each hole to firm up the post against the ground underneath. I don't know how deep you'd have to go to just use bare lumber in the ground.
My home store expert just built one like this, and he said to be sure to use 12" floor joists both for stability and so you can use a full 12" insulation batt in between the joists to insulate the floor. Joists are placed 24" apart (the same width as standard insulation).
What kind of building are you erecting?
imautoparts is offline   Reply With Quote
Old 10-17-2012, 06:21 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
check out this link for information regarding the use and construction of wooden foundations. This is the requirements of the 2009 International Residential Code.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
imautoparts (10-17-2012)
Old 10-17-2012, 06:29 PM   #5
Rewards Points: 372
That is a great link. I'm glad to learn there are standards for treatment quality on the timbers. Be sure you give that a good read. Also, it would be good to check local permit restrictions (if any).
At least here in Indiana and NW Ohio, code and permitting do not apply if you are building your own house on your own land outside a town or city with local restrictions (rural property). They are currently trying to extend that protection to business buildings like barns as the Amish locally are receiving pressure from the State to get permits and inspections when they build barns - something that is very unacceptable to that community and somewhat laughable, since Amish carpenters represent 90% of the building trades in this area.
By the way, the title of this post:
Originally Posted by grkeenan View Post
Wood For Foundation R.S.K.
What in the heck is R.S.K.?
The Following User Says Thank You to imautoparts For This Useful Post:
mae-ling (10-17-2012)
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
