Old 11-03-2011, 11:32 AM   #1
Wood floor padding silence underlayment insulayment
I live in an apartment built 5 feet high on stilts/telephone poles.
This is my subfloor, 3/4 inch plywood. It is severly warped because of uneven pressure from the supporting poles.
I am trying to make it level with a combination of shims and sheets of plywood like this, but with more shims than shown:
The floor should look like the part on the left when I am done and it should be fairly level:
I want to install solid hardwood floor from lumber liquid.
I want it to be quiet.
Which underlayment should I use? Dream home Insulayment?
http://www.lumberliquidators.com/cat...productId=2008
Where should I sandwhich the underlayment for maximum silence? Between the shim layer and the final plywood sheets?
Should I use glue to fix the hardwood planks to the final layer of levelled plywood?
Thanks!
shinyhalo is offline   Reply With Quote
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Underlayment: Insulayment vs. Floor Muffler monkeystomach Flooring 1 11-12-2010 06:54 AM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
