Wood Floor Over Garage Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2013, 09:54 PM   #1
Rewards Points: 212
wood floor over garage floor
Hello folks,
I have a garage that I wanting to turn into living space. There are 2 steps down from the house into the garage. The house joists are 2x8. What I want to do is tie into the house joists and frame a floor over the garage.
When I do this, there will be appox 7 inches between the bottom of the joists and the concrete.
I am planning on venting the space.
I am wondering if this is code to do this since there is not enough space for a man to crawl in. So technically its a crawlspace that is uncrawlable.
Code says you must have 18 inches of clearance.
Is this situation considered differently than a regular crawlspace?
bluebird5 is offline   Reply With Quote
Old 09-29-2013, 06:56 AM   #2
Rewards Points: 12,858
That would need to be discussed with your local building inspector.
I my area if it's less then 18" I have to just use pressure treated wood.
I've done some with engineered floor joist.
Post some pictures of the outside of the garage.
One big deal is how the area where the overhead door is now.
In most cases the right way to do it would be to make it look there was never a door there in the first place.
Get rid of the old apron, build a stem wall so water will not get in under the wall.
Remove all the siding on that wall and reinstall it so there no sign of the old design.
Old 09-29-2013, 10:56 AM   #3
Rewards Points: 1,016
Garage conversions and how they are done are closely scrutinized in many areas. Suggest you ensure proper permits are in place before doing any work to save yourself rework and grief.
____________
Vince
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
problem: Water on wood floor during refinishing HouseMgr Flooring 2 08-15-2009 10:19 PM
Wood floor help/suggestions bigboyjoel Flooring 18 12-31-2008 01:02 PM
