Wood Fence With Steel Posts Gate Question. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 02:20 PM   #1
Wood fence with steel posts gate question.
I am in the process of planning out my fence and have decided to go with steel posts and wood facing.
My issue is I cannot seem to find any info how you attach the gate to the post but still have the post wrapped in wood using something like the below.
Link removed
If there is some other hinge or way I should research please let me know.
dabeast is offline   Reply With Quote
Old 04-05-2013, 10:56 AM   #2
Any advice from anyone?
Old 04-05-2013, 11:10 AM   #3
Roofmaster
Rewards Points: 2,172
Why cant you just use regular chain link fence gate hardware?
Old 04-05-2013, 01:01 PM   #4
AHH, SPANS!!!
Rewards Points: 1,166
check out the gate hardware section at your building supply, there are lots of options. the adjust a gate and ez gate systems works well for gates and has multiple options for attaching to posts
hand drive is offline   Reply With Quote
Old 04-05-2013, 01:12 PM   #5
Too Short? Cut it Again!
We talking a fence gate here or one wide enough to let all four of your Escalades, your truck, the wife, and your branded herd of cattle in at once?
How wide will your gate need to be.
Old 04-05-2013, 01:34 PM   #6
Just your standard walk through gate. If you see above those brackets allow you to box in the metal posts with wood.
What i'm looking for is how you would do the gate post boxed in with wood.
P.S. I'm putting a rolling gate across the driveway
Old 04-06-2013, 02:10 PM   #7
I would pour a sanitube or wood framed concrete base to anchor the post and to the dimension you want for the final look. Frame up to a collar you make to go around the top of the post and that matches the base, tapers, or whatever. Leave enough clearance in the collar so the steel post can move and flex on its own without touching or stressing your wood structure. Fix your wood siding to the framing. Stain or prime and paint.
Hardware should still be on the steel post. You can get plates with extended hinges just for this kind of thing. Or metal shop or blacksmith can make custom ones for you for not much money.
Treated wood for anything near ground of course. Or redwood or cedar.
I can diagram if this is not clear?
Old 04-08-2013, 12:52 PM   #8
Just realized by link from the OP got removed.
What i'm looking to use is the Jaws II bracket from oz-post. I allows you to wrap a steel post with wood so the post of the fence are metal instead of wood.
I'm thinking I might just notch out the side of wood where the hinge will be attached to the metal post. Unless anyone has any other ideas.
Old 06-25-2016, 02:44 AM   #9
Rewards Points: 2
Re: Wood fence with steel posts gate question.
Why don't you try chain link fence. It is easily available in hardware shops. Or if you want complete installation of chain link fence. you can contact Fence Factory Fence Factory Rentals if you residing in California.
hannahmayer is offline   Reply With Quote
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Corrugated steel fence? ITSANSS Landscaping & Lawn Care 2 04-13-2011 08:04 AM
Replacing fence question about fence posts tstesprit Building & Construction 6 03-19-2011 10:47 PM
Gate for Wire Garden Fence edge10 Landscaping & Lawn Care 1 07-05-2009 02:00 PM
