Wood Fence With Metal Post - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 12:27 AM   #1
Wood Fence with metal post
2 years ago I used metal post to build a wood fence instead of using 4x4/6x6s. It came out good. I just ran into trouble building a gate what I made did work but I would like to make something that's a little better with a better lock.
Right now I use a master lock and also use a chainlock around the post to the gate. Here are some pics I took when I did it 2 years ago and I did go back later and trim the post to height.
I was thinking of building a fake 4x4 where it would be hollow in the inside to wrap the one post so maybe I could install a better gate locking system or does anyone have any better ideas
BDestroyer8418 is offline   Reply With Quote
Old 06-08-2009, 05:57 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Look at HD for the square white PVC posts where they have the fence sections. Also check Lowes.
I like your Crawford sawhorses. I have a set because they are adjustable up to a decent height.
http://www.homedepot.com/webapp/wcs/...ctId=100003259
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-08-2009, 10:53 PM   #3
I'll have to check it out thanks.
Anyone else have another suggestion.
Yea I just got them in those pics didnt even add a 4' 2x4 on it at that time. They are nice it is a pain sometimes to get them adjusted for height but alot better than those other aluminum horses and these barely take up any room and can hold a ton.
Old 10-11-2009, 11:54 AM   #4
This is the way I built my gate. I do not know if it helps, but it might give you some ideas. I did add a cross brace to prevent sagging. Also, on those corner braces, did you have any problems with them cracking? I bought eight and only got two bolted down without them cracking. I checked the pipe for the right diameter and the depth inserted into the bracket and every thing checked fine. The two outside bolts tightened up just fine, but the minute I tightened the center bolt they would split. Gary
Wood Fence with metal post-gate-001a.jpg   Wood Fence with metal post-gate-004a.jpg
WB6VVV is offline   Reply With Quote
Old 07-20-2010, 10:22 AM   #5
This is an old thred, but it's just what I was looking for in terms of ideas for my twice sagging double gate. Where would I get the pipe and corners for the pipe? Any guesses as to the size.
Anne is offline   Reply With Quote
Old 07-20-2010, 01:55 PM   #6
This is the latest gate that I built. It is 48 inches wide X 6 feet high. The pipe is regular 1 3/8 chain link fencing pipe the ells are standard. I have attached a copy of the specs for your info. You can get the materials at most home supply stores. I got mine from home depot. The brace is made out of a piece of inch EMT. I can make detailed directions and more pictures if you need more info.
Wood Fence with metal post-south-house-07-14-10-p1.jpg   Wood Fence with metal post-1-3-8-gate-ell.jpg
The Following User Says Thank You to WB6VVV For This Useful Post:
Anne (07-20-2010)
Old 09-18-2011, 04:33 PM   #7
Rookie Question
Rookie question here... I am modeling my fence gate after the samples above, which I think are fantastic and look great. I am making a double gate using a 8 foot fence panel cut into halves.
My rookie question is, what's the best way to attach the metal framework to the fence panel?
bginda2g is offline   Reply With Quote
Old 09-24-2011, 08:42 PM   #8
I just bolted 2x4s to the horizontal bars with carriage bolts, and screwed the dog ears to these 2x4s See attached photos.
Wood Fence with metal post-fence-gate-detail-005.jpga.jpg   Wood Fence with metal post-fence-gate-detail-008.jpga.jpg
Old 09-24-2011, 10:49 PM   #9
Knucklez's Avatar
Rewards Points: 930
what about using only one post and the gate is a bit wider and locks at the house wall instead? Its a bit akward due to the angle, but it could work and it would eliminate one of the posts.
or another idea would be to have the gate slide open on catelever, no swing open at all.
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
porch post vinyl or metal to stop painting? hobbyguy2002 Building & Construction 2 01-28-2008 04:37 PM
Staining Wood Fence art2670 Carpentry 2 11-14-2007 01:15 AM
chain link fence post removal Designman20 Landscaping & Lawn Care 3 07-05-2007 10:52 AM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 02:09 PM
