Wood Deck 4x4 Footing Spacing ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-20-2010, 10:01 PM   #1
Expert Jimmy Hacker
JimmyWacked's Avatar
Question
Wood Deck 4x4 Footing spacing ?
Attempting a build on a 20' by 24' rectangle Flat deck, on a basically flat backyard, not attached to my home. I'm burying 4x4 posts in Concrete as I did with my large fence. I will attach 2 x 6 or 2 x 8 deck joists to these posts. → I can't seem to find a norm for spacing each of the 4x4's in the ground. Is there a rule of thumb.?? I must have missed it~ ?
JimmyWacked is offline   Reply With Quote
Old 04-20-2010, 10:06 PM   #2
Where are you located ?
Old 04-20-2010, 10:11 PM   #3
Expert Jimmy Hacker
Copy, thxs !
INDIANA.~
Old 04-20-2010, 10:17 PM   #4
Pro
Nostco's Avatar
You won't be attaching joists to posts, you will be attaching joists to beams
Your posts will go on footings (preferrably sono tubes)
The size of the beams, live load/dead load of the deck will get you closer to the answer.
First thing first, you need drawings and depending on where you live most likely you will need a permit.
Nostco is offline   Reply With Quote
Old 04-20-2010, 11:49 PM   #5
Expert Jimmy Hacker
Yes. Thxs. Got that--- but again- what is the required spacing between cement/wood 4x4 footings?
Old 02-20-2012, 02:05 PM   #6
The spacing depends on the load up top. For example, if it's just a walking area and nothing else, 8' is the furthest you go apart. If deck table and chairs where many people will be sitting, then 5-6' apart. The more the better though, 6' is where I would go
ukisgr8 is offline   Reply With Quote
Old 02-20-2012, 03:07 PM   #7
Civil Engineer
Rewards Points: 4,944
Normally a deck is designed and constructed according to some type of code, even if you don't need or plan to pull a permit. I recommend the Prescriptive Residential Wood Deck Construction Guide, which is based on the International Residential Code. You can find this document at no charge on the internet, or your building inspector may have an extra one (mine did).
The Code has details regarding spacing of posts, minimum size of posts, connection details between posts, beams and joists, maximum length of joists and beams, and lots of other details which are quite useful (example how to attach a ledger board to the house).
Possibly you don't like codes, or you want to "go your own way". That is certainly an option. In that case, the required spacing of the posts will be based on the deck loading, the span of the beams, and the geometry of the deck. If you don't want to use the "standard" sizing that the Code gives you, your option is to compute the required size for each element based on some assumed loading you determine based on knowledge of the used of your deck. This is a lot of work, and frankly pretty useless, since it has all been worked out in the Code, but if you insist, that is how to decide on the spacing. Oh, and by the way, 6x6 is the minimum allowable post size per the Code.
Old 02-20-2012, 09:53 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
from what i gather this deck is just sitting on grade, the only reason your using the posts is to keep the deck from shifting around in the yard am i correct.
if in fact it is sitting on the ground and fully supported, it doesnt require beams. you should just need posts at the corners along with every 8 ft..
if it were actually up off the ground the distance between posts would depend on local codes, what size joists and beams your using
woodworkbykirk is offline   Reply With Quote
Old 02-21-2012, 09:03 AM   #9
Expert Jimmy Hacker
ITS ALL DONE GUYS.. My post was from almost 2 years ago- !!
I went just about 5 ft between all 4x4 posts ~
DONE
It's all good.!
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Staining problems on Cedar deck pomi Painting 6 09-24-2009 02:23 PM
Patio Around an Existing Deck tonyg Landscaping & Lawn Care 1 09-10-2009 06:57 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
Help on Staining my wood deck thedirkus Painting 3 06-12-2007 08:28 PM
