Wood For Concrete Expansion Joints - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 06:13 PM   #1
Rewards Points: 248
wood for concrete expansion joints
Can I use a 2x4 for a concrete expansion joint or does the expansion joint have to be a 1x4 furring strip?
jackwashere is offline   Reply With Quote
Old 02-18-2013, 06:16 PM   #2
Civil Engineer
Rewards Points: 4,520
Are you asking how to form up for an expansion joint, or were you thinking of leaving the wood in place?
Old 02-18-2013, 06:53 PM   #3
Rewards Points: 12,840
If you tell us what it is your trying to do it would be a big help?
Old 02-18-2013, 07:16 PM   #4
joed's Avatar
Rewards Points: 11,576
The wood will eventually rot out and you will have a rather large gap left by using a 2x4.
Old 02-18-2013, 10:10 PM   #5
Rewards Points: 248
Sidewalk that connects two 10x12 structures. The structures are built on 18 inches below grade and 12 inches above grade foundations (to avoid high waters during rains). In between the structures is an existing 4" slab. So I'm thinking of putting expansion joints between the foundations and sidewalk and between the slab and sidewalk. Ideally I would like to remove them after the pour but from my experience wood can be awfully difficult to remove if the concrete latches onto it.
Old 02-18-2013, 10:18 PM   #6
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
Pavement expansion joints .......expanding! RetiredSoldier Building & Construction 11 07-18-2011 01:12 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
