Wood Column Rotting - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 03:46 PM   #1
Wood Column Rotting
I have a wood column on the end of my porch that is rotting and porch celing is becoming unlevel. It is sitting on concrete. How do I replace this column?
dkkemp is offline   Reply With Quote
Old 02-24-2013, 03:54 PM   #2
Rewards Points: 13,750
Post a picture.
If it's sitting in driect contact with the slab it's going to rot.
It was suppost to be sitting on a post base to keep it out of the moisture.
Going to have to use a bottle jack and a 4 X 4 to lift enough to slide it out, cut it off and add a post base.
http://www.amazon.com/Simpson-Strong.../dp/B000VYER68
Old 02-24-2013, 06:11 PM   #3
If its a round column or something decorative you may be able to cut some of the bottom off and sit it back down on a pressure treated platform. You will need to jack up the roof about a half inch to remove the column. As suggested above, use a jack. even a car floor jack will work. Screw a 2 x 4 diagonally across the ceiling about 6 inches behind the column, from the front to the side. Then jack it up slip out the column and do your repairs
JonM is offline   Reply With Quote
Old 02-24-2013, 11:32 PM   #4
Do not use pressure treated, use vinyl or a post base instead.
Never use a car jack!!!
And it does not need to be lifted 1". If you did somethings going to break.
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 09:05 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 05:04 PM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 04:16 PM
