Wood Burning Insert In Heatalator - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 07:05 PM   #1
Wood Burning Insert in heatalator
Greetings all. Newbie here. I have a fireplace that is a heatalator, in which I want to install a woodburning insert. I have found an insert that will fit, and the existing fireplace has never been used. It's about 5 years old and is up to specs. Can anyone advise me whether or not I can expect any problem with this? Has anyone done this successfully? unsuccessfully? Hints? Suggestions?
Thanks in advance
Ron Z
rzacc is offline   Reply With Quote
Old 11-30-2010, 06:00 AM   #2
firestarter
i would be sure your flue will line up , yes it is poss. to install but be sure you have the existing flue cleaned . and on some heatilator units you cannot remove the refractories because of the heat coming off the wood insert. consult man. about this first.
firestarter is offline   Reply With Quote
Old 11-30-2010, 06:22 AM   #3
Originally Posted by rzacc View Post
greetings all. Newbie here. I have a fireplace that is a heatalator, in which i want to install a woodburning insert. I have found an insert that will fit, and the existing fireplace has never been used. It's about 5 years old and is up to specs. Can anyone advise me whether or not i can expect any problem with this? Has anyone done this successfully? Unsuccessfully? Hints? Suggestions?
Thanks in advance
ron z
Hire this out to a professional...................!
mark942 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Fireplace Heatilator and wood burning insert mmadden68 HVAC 5 03-29-2011 11:13 AM
Wood Burning Stove Pipe Question jh756 HVAC 1 08-20-2010 02:19 PM
Wood insert trouble...HELP! numbah37 General DIY Discussions 9 02-17-2008 12:54 PM
Wood Burning FP needs flue extension Renee Building & Construction 1 08-29-2005 05:26 AM
