Old 08-28-2010, 07:18 PM   #1
wood beam span
i would like to open up my basement. there is a 2 x 6 supporting wall i would like to open up 9'. could it be done with a 3ply 2x12 beam 10' long.
inneedofadvise is offline   Reply With Quote
Old 08-28-2010, 07:35 PM   #2
Tom Struble's Avatar
wood beam span
maybe
Tom Struble is offline   Reply With Quote
Old 08-28-2010, 09:27 PM   #3
Moderator
wood beam span
With only distributed loads and no point loads above (doorways, posts, etc.): http://ftp.resource.org/bsc.ca.gov/t...2_page0376.pdf
Be sure to add solid wood blocking in the floor under the two jacks on each side.
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
inneedofadvise (08-28-2010)
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 11:56 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Beam Sizing Riddler Carpentry 14 08-05-2006 01:46 AM
