Old 11-03-2008, 10:31 AM   #1
Wood Beam
Hi,
I am planning on building a new cabin next spring utilizing 12" concrete piers as the foundation system. The cabin will be 24 feet deep by 30 wide. I will place 3 rows of piers, with 4 piers per row spaced 8 feet between each pier within the row. There will be a span of 15 feet between each row of piers. By question is this, what size of wood beam should be place on top of the concrete piers. I plan on using 2x12 floor joist on 16" centers placed on top of the wood beams. The floor joist will have a 15 foot span between the wood beams. The cabin will be a single story structure. Any advise will be greatly appreciated.
Best Regards,
Dan
dhatley4 is offline   Reply With Quote
Old 11-03-2008, 02:09 PM   #2
MetalArchitect
Wood Beam
I think it would be better doing something like this...and your spans are less.
I would use bolt together (3) 2X12s or use a LVL
Rkeytek is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
