Wood Basement Walls Wet At One Time - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 10:16 PM   #1
Wood Basement Walls Wet at One Time
The basement is 1/2 block and 1/2 wood walls, the wood walls being on the walkout side, none of the wood is below grade. The walls had insulation put in and it was just sitting there, no vapour barrier. The mice got in and made a mess and insulation eventually fell out in many places. There are no signs of water entering from the outside but the walls have been wet and are greyed, mold? The house was heated for 2 winters with just this pink insulation and no vapour barrier ... could this be from condensation build up? Brand new house basically abandoned, last 8 years. I want to fix it up to sell but am concerned about the source of
the moisture but as I said .. it doesn't seem to have come from outside at
all. thanks
Mswalleye2 is offline   Reply With Quote
Old 03-31-2013, 10:37 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
if you could edit your profile to include your location it would certainly help in getting useful responses as location determines how buildings are to be constructed.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-04-2013, 10:53 PM   #3
This house is located just east of Minneapolis, MN on the Wisconsin side. Another site mentioned moisture in the walls due to the high humidity of the area but there was no vapour barrier on the inside of these walls to trap the moisture so I am leaning towards condensation on the walls due to temperature variance but I don't know. The place was housewrapped so could that have trapped moisture within? I noticed the corner beads in some rooms is getting rusty too..
Old 04-05-2013, 10:22 AM   #4
Roofmaster
Rewards Points: 2,210
Pictures? They would help a lot.
Thanx
Old 04-05-2013, 01:07 PM   #5
Rewards Points: 4,644
tape up a 2.0 x 2.0 pc of plastic sheeting for a few days & check where the moisture collects,,, between the plastic & the wall, its being transmitted thru the walls,,, on the face of the plastic, its condensation from room air
Old 04-05-2013, 03:48 PM   #6
Okay pictures were posted under photos? Good idea about putting up some test plastic, thanks. Thanks for your patience.
Old 04-06-2013, 10:43 PM   #7
Registered User
Rewards Points: 5,514
"The walls had insulation put in and it was just sitting there, no vapour barrier."
"The house was heated for 2 winters with just this pink insulation and no vapour barrier ... could this be from condensation build up?"
" I noticed the corner beads in some rooms is getting rusty too." No drywall in basement on the walls, just insulation w.o. vapor barrier. Yet corner bead is rusting under the drywall texture.... I'm confused. The moisture is from the gas furnace or the moving air is lifting moisture from wet areas to spread it on the colder walls where it condenses to water from vapor. Due to temp diff., as you said correctly; http://www.buildingscience.com/docum...bout-diffusion
Gary
PS. How To Post Photos Using PhotoBucket Or Flickr
Old 04-06-2013, 11:16 PM   #8
The corner beads upstairs, sorry for the confusion. Thanks for the feedback.
The Following User Says Thank You to Mswalleye2 For This Useful Post:
Gary in WA (04-06-2013)
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 12:36 PM
What to do with basement walls. RR. Remodeling 3 02-20-2012 06:49 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 06:09 PM
basement walls chuckofaltrades Painting 1 10-27-2009 09:51 PM
