Women & A Greenhouse - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-06-2014, 09:17 PM   #1
Women & a Greenhouse
My plans for the GH is calling out for a 1x8 ridge board with 2x4 rafters. Always thought you go up the next size from the rafters and in this case a 2x6? A 1x8 seems a little flimsy but perhaps it is because the window/vents attach to the ridge board. Can I double up on the ridge board? Any thoughts on the right way to go about this??
Jes32566 is offline   Reply With Quote
Old 05-06-2014, 09:40 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
What is the length of the rafter and the roof pitch?
Old 05-06-2014, 09:46 PM   #3
Rafters are 5'11" and roof pitch is 10/12
Old 05-06-2014, 10:04 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
A ridge board is actually not needed unless there are no ceiling joists or something to tie the outside walls together, to keep them from spreading. Rafters can be installed without a ridge board all together. What a ridge board does is keep the rafters in an upright position until the decking can be applied. A ridge board just makes it easier to frame.
If there are no ceiling joists, or something, that will tie the walls together to keep from spreading, then a ridge board will need to be replaced with a supported beam that will support the rafters and keep the pressure off the outside walls. You will be fine with a 1X8, but if you feel more comfortable using a 2X8 that will be fine also. Usually with 2X4 rafters a 1X6 or 2X6 is used instead of a 1x8 or 2x8.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 05-07-2014, 12:41 AM   #5
Registered User
Rewards Points: 4,910
Might check locally if a permit is needed, I read that your location some HO's cannot even change out a window themselves due to high winds/liability...
Gary
Old 05-07-2014, 01:27 AM   #6
Rewards Points: 332
Send a message via Yahoo to curtd
For 10/12 pitch go with BigJim's comment above. But, being a perfectious (i'm sometimes a pain in my own a__) i would go with 2 X 6 for the rafters especially if you sometimes get a lot of snow
curtd is offline   Reply With Quote
Old 05-07-2014, 04:42 AM   #7
An old Tradesmen
Rewards Points: 6,086
The OP being in Navarre, Florida. Probably never has to worry about snow on the green house.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
curtd (05-07-2014), roofermann (05-07-2014)
Old 05-07-2014, 07:26 PM   #8
GHouse
Thanks Big Jim and everyone else. Very helpful info. No snow here is right. Had enough of that when I came down from Illinois. Traded the snow for white sandy beaches!! K, thanks again guys. God Bless.
Jes
Old 05-07-2014, 10:44 PM   #9
Rewards Points: 332
Yep, I missed that one
1x4 joists in my greenhouse?? BrewinBend Building & Construction 15 08-11-2013 11:16 AM
Building a Greenhouse Frank Rizzo 951 Gardening Forum 7 05-24-2013 04:13 AM
Light my greenhouse please Saundra1010 Electrical 4 03-18-2012 08:45 PM
insulating a slab w/o footer for greenhouse dc loud Building & Construction 2 04-17-2010 08:04 PM
Slab foundation for 16 x 20 greenhouse prices? sailorfred Flooring 2 06-06-2006 08:25 AM
