Wobbly Shower Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 10:31 AM   #1
wobbly shower wall
Hi, I'm looking for tricks on how to improve the stiffness of a short shower wall. The wall is about 22" wide, by 6'6" high and does not go all the way to the ceiling. I plan on hinging my glass shower door from this wall, so it needs to be stiff. Other than taking the wall all the way up to the ceiling, are there some tricks I can use to stiffen it up?
Thanks in advance!
red86yota is offline   Reply With Quote
Old 02-25-2009, 10:38 AM   #2
Whatamess
Post some detailed pictures if you can.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 02-25-2009, 10:43 AM   #3
sorry, I should add that the wall comes out perpindicular to the bathroom wall. Here's a sketch of the short wall I'm talking about...
Old 02-25-2009, 11:49 AM   #4
Registered User
Termite's Avatar
You could run your studs down through the floor and attach them to blocking nailed between the floor joists. That's the only way I know to stiffen a wall that isn't full height. If your wall lands directly on a joist (parallel direction), you're out of luck. I don't think it will work good enough to hang the door off of anyway.
I've also seen elaborate heavy gauge welded steel skeletons incorporated into the wall and floor system beneath in an effort to stiffen a kneewall.
Angle brackets on the floor won't do it, I promise.
If the glass door has to hinge on this wall, I'd seriously recommend reconsidering not taking the wall to the ceiling. Glass doors are heavy and place dynamic loads on a wall, especially a wall that isn't secured at the top. Even if only two or three studs go all the way up (right above where the hinges mount) you'd completely and adequately stiffen the wall.
Old 02-25-2009, 11:56 AM   #5
yeah, I'm thinking I might just have to take the wall all the way to the ceiling. thanks for the input.
Old 02-25-2009, 12:02 PM   #6
A sheet of plywood 3 1/2 " wider than the short wall, covering the short wall and a stud placed in the other wall, along with a metal L bracket on top.
Mop in Hand is offline   Reply With Quote
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 02:30 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
retiling shower wall, possible water damage cwel Remodeling 4 12-17-2007 04:57 PM
