Wire Mesh For Vents Rather Big? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 01:02 AM   #1
Rewards Points: 366
Wire mesh for vents rather big?
I notice that vents used on roof, in sheds, and also for crawl spaces seem to be rather big in the mesh screen hole size, not fine small hole mesh like screen doors and windows. At least that's from what I see visiting homes in my area, see on my own house, and on sheds sold at Home Depot.
I would think the larger hole sizes of the somehat sturdier mesh would allow insects and pests into shed/roof/attic/crawlspace. Is it desirable or some reasoning to using that type of mesh over a fine screened mesh in these areas? I figure you could better mitigate drywood termite infestation this way in terms of minimizing gaps the swarmers can fly into.
daluu is offline   Reply With Quote
Old 12-04-2012, 07:09 PM   #2
Registered User
Rewards Points: 526
Rodents climb up house walls to gain entry at eaves through ventilation holes. 1/4" is sturdy hardware cloth, stops most as some mice can go through that size hole. Hard to gnaw through it, unlike screen door screen.
Code: "R806.1 Ventilation required.
Enclosed attics and enclosed rafter spaces formed where ceilings are applied directly to the underside of roof rafters shall have cross ventilation for each separate space by ventilating openings protected against the entrance of rain or snow. Ventilating openings shall be provided with corrosion-resistant wire mesh, with 1/8 inch (3.2 mm) minimum to inch (6.4 mm) maximum openings." From: http://publicecodes.cyberregs.com/ic...3_8_par071.htm
The more wire/louvers metal per square inch the less "Net Free Venting Area (NFVA) there is; http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Apply Wire Mesh For This Parging Patch Job? Quackerjack Concrete, Stone & Masonry 3 12-03-2012 09:40 PM
How do I attach wire mesh to Nudura foam? JAS135 Building & Construction 0 12-01-2012 11:27 AM
Ceiling fan and wire gauge needs? greentrees Electrical 6 05-01-2012 01:05 AM
do i need to use a scratch coat and wire mesh on cement board(floor) Limit54 Flooring 10 12-03-2009 06:24 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
