Winterizing Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 12:16 PM   #1
Winterizing windows
I live in minneapolis and have a fairly new home (2001) with double paned hung windows. Last winter I noticed a draft through the edges and I'd was wondering what I can do to winterize. I have heard about the heat shrink plastic but I'd like to avoid it if possible. Any other choices?
Thanks!
wariarr is offline   Reply With Quote
Old 10-12-2008, 12:32 PM   #2
Rewards Points: 6,652
Only thing you can do at this point, is to pull of the Window trim and see if you can shoot in some low density foam. Otherwise, it sounds like Insulation was not placed around the edges of the window during install, or there is no vapor barrier.
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 10:34 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 09:07 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
