Winterize Built On Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2012, 09:50 AM   #1
Winterize built on porch
Morning all!
I live in an older house, built probably early 1920's in Illinois. The built on back porch has 4 sliding windows (drafty), a bare cement floor (painted green by the landlords), and the back door that leads to the back yard. This summer I moved all my work out equipment to the porch because the basement was way too dusty and gross to work out in lol. Any tips on how I can seal up these windows for just the winter and cut down the temp in the room? I tried those plastic sheets with the hair dryer last winter and honestly did not do much. Any input would be great thank you!
BossSampson is offline   Reply With Quote
Old 05-29-2012, 10:22 PM   #2
Rewards Points: 2,212
Plastic the outside as well as the inside.
The walls probably have little or no insulation and the concrete floor is probably cold.
Your renting right?
mae-ling is offline   Reply With Quote
Old 05-30-2012, 02:36 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
if you're a renter what mae-ling said is about all you can do. You are not allowed to open the structure or make changes on your own.
photos are always welcomed so that we can see what you see .... maybe able to make some non-invasive suggestions after seeing what we have to work with
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
mae-ling (05-30-2012)
Front Porch - Repair or Completely Replace? DIYerIT Building & Construction 1 05-26-2011 12:58 AM
Porch Flooring Recommendation RyanS. Flooring 0 04-16-2011 11:31 AM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 11:14 AM
PORCH - from BRICK to WOOD Kukurigu Building & Construction 1 11-12-2005 09:33 PM
Porch rebuild question Unregistered General DIY Discussions 1 11-26-2004 04:20 PM
