Winter Is Here - French Door Water Condensation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2013, 07:33 PM   #1
Rewards Points: 161
Question
winter is here - french door water condensation
Moved into a new place, the heating vent is right next to the french door that goes outside...so every night there seems to be a build up of water that runs down and ice builds up at the bottom of the door on the inside. My concern is there will be a lot of water at some point and possibly run under the laminate flooring and cause issues?
We broke the molding off because the door kept icing shut to it and wouldn't open, haha...oy! Any advice on how we can stop this?
We've already blocked off the heating vent from shooting heat up the side of the door, still seems to get some good condensation and ice chunks at the bottom.
vivithemage is offline   Reply With Quote
Old 12-11-2013, 07:43 PM   #2
Rewards Points: 13,446
Lower the humidly in the home.
Seal up any air leaks around the door.
Old 12-11-2013, 07:47 PM   #3
Rewards Points: 161
woops, I had central humidifer set to like 40 ... for summer. I put it down to 15.
Old 12-13-2013, 01:09 AM   #4
Rewards Points: 1,092
here is one opinion on humidity levels, from wikianswers. "Outside Temperature Indoor Relative Humidity: Above 50 F, not over 50%. Above 20 F, not over 40%. Between 10 & 20F, not over 35%. Between 0 & 10F, not over 30%. Between -10 & 0F, not over 25%. Between -20 & --10F, not over 20%. -20F or below, not over 15%. If you try to put more moisture into the air, the cold windows will probably start to condense the water back out."
IMO, your problem may be the window quality, and you may need to get good, air-tight double or triple pane windows, filled w/ gas (argon, xenon, krypton.... but then you can't have Superman over....)
Old 12-13-2013, 07:56 AM   #5
Rewards Points: 161
Good advice! That's pretty much what my central humidifier says. When I moved it down problem gone . Glad it was a simple thing!
French Drain Merge into Solid Drain catahoula22 Landscaping & Lawn Care 0 07-19-2013 01:38 AM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
window condensation kmpittman Windows and Doors 4 11-29-2011 09:10 AM
sweating double pane windows etch Windows and Doors 6 10-31-2011 09:30 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
