Winter Heat To Protect Foundations - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 08:48 AM   #1
winter heat to protect foundations
how much heat do you need in the basement to protect the foundation walls from cracking in the severe cold months? all framing of the house is completed.
barbara hackett is offline   Reply With Quote
Old 01-04-2012, 09:40 AM   #2
Rewards Points: 13,694
Foundations do not need to be heated, in fact if it was warm on the inside and cold on the outside it could do more harm then good, not likly but remotely could.
Foundations fail most often because there was a poor footing they were built on, nothing to do with not being heated.
Old 01-04-2012, 02:50 PM   #3
Concrete & Masonry
Rewards Points: 568
What you need to be concerned about is frost getting under the footings and post pads and doing damage. If the floors in (likely not in at this point yet) they can be damaged from frost heave as well.
You can either use temporary heat, or insulate very well to trap the earth's heat in. Depends alot on where you are, how extreme your winter weather is, and how long before you can get the house insulated.
As for how much heat? Just enough to keep the basement from freezing, but I can tell you from experience, a house at this point of the process uses ALOT of fuel to keep it from freezing on the extremely cold days......
jomama45 is online now   Reply With Quote
Old 01-04-2012, 05:37 PM   #4
Rewards Points: 6,652
My basement is anywhere from 62 in the Winter, and around 70 in the Summer. All I have down there are two vents to help keep the space dry and stop the stale air smell.
Before we got central air, the basement would get to 76, while the upstairs was around 72, with three window units coolong the house, one was always running 24/7, others when we got home after work.
From wood burner heat to ??? spiceoflife HVAC 5 01-02-2012 04:32 AM
Need to protect new cedar railings and post for winter tgm1024 Painting 4 11-27-2010 06:20 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Rheem Package Heat Pump Newbie03 HVAC 4 02-26-2010 06:32 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
