Wine Rack As Load Bearing Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 12:04 AM   #1
Wine rack as load bearing wall?
I am going to open up my kitchen and will need to knock down a load bearing wall. This will obviously require me to replace the load bearing wall with a load bearing post. However, I don't just want a boring post in the middle of the kitchen. I'd rather incorporate some design element. My idea is to construct a load bearing wine rack made out of two adjacent load bearing posts, preferably a metal/steel/cast iron post. I understand ultimately that I need to involve an engineer, but before I do that, I'm wondering if this is even a possiblity. I don't know anything about load bearing properties and whether there are such a thing as metal, steel or cast iron load bearing posts that could act as load bearing posts. If so, how wide are these? The narrower, the better. Any help or experience with something like this would be very much appreciated!!
lisa7932 is offline   Reply With Quote
Old 02-27-2012, 12:13 AM   #2
Rewards Points: 13,270
You do not just knock out the wall and just put a post in.
Both ceilings get temperay walls built to support them. The wall come out and a header is built to span the opening at the top with whats called jacks (2 X 4's under the header) to support it.
There aslo has to be added supports under that floor in the crawl space or basement under the jacks to support them.
Once the headers in place you can add anything or nothing in the new open space.
http://www.carpentry-pro-framer.com/wall_framing.html
Nailbags (02-27-2012)
Old 02-27-2012, 12:45 AM   #3
Rewards Points: 626
Best answer given.
Nailbags is offline   Reply With Quote
Old 02-27-2012, 01:07 AM   #4
That is not what my architect told me. He told me that I could replace the load bearing wall with a support post/column to help carry the load. My question is, rather than using wood posts that are load bearing, can I use some type of metal load bearing post?
Old 02-27-2012, 01:29 AM   #5
Why would you want a metal coloum to show in a room? It would look like the steel post in a basement.
Look a whole lot better to frame it it like I suggested and you could had some coloums for looks.
http://www.columns.com/
Old 02-27-2012, 01:53 AM   #6
Maryland
Your architect only gave you the "before and after" parts of the procedure. You can't just remove a load bearing wall and then pick up and install a support post in it's place. As Joe mentioned, you need to temporarily support the ceiling before removing the wall. After the wall is out, you would install an appropriately sized beam to carry the load. The beam would sit on top of your support posts which in turn need to be sitting over an adequate footing. To answer your question, yes, in most situations a metal support post can be used.
Pittsville is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Looking into removing a load bearing wall IRuehl Remodeling 5 07-02-2011 04:39 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 08:43 AM
