Windows Wrapped With Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2008, 11:24 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
windows wrapped with drywall?
I plan on "wrapping" my windows in my basement with drywall.
The "ledge" of the window and the sides and the top is approx. 12 inches away from the wall. They are deeply set, as I has to build my studs away from the wall.
Do I have to finish them with corner bead, and mudding, etc?
I do plan to put a trim around it.
What I'm asking, is do I have to install corner bead or can I just put the trim on?
(Have I made this as clear as mud?)
yummy mummy is offline   Reply With Quote
Old 03-04-2008, 03:29 PM   #2
Yes, you need to cornerbead and mud the the corners. It will give you a sharp edge to put the trim on.
jerryh3 is offline   Reply With Quote
Old 03-04-2008, 03:32 PM   #3
Thanks jerry, I guess I have more corner beading to do.......
Old 03-04-2008, 04:31 PM   #4
You could always case them out with wood...
Old 03-04-2008, 10:52 PM   #5
That sounds like a great idea, but I am way too much of a newbie to try that one.......
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 10:34 PM
Cutting drywall to put in windows down a stairwell ragtopdave06 Remodeling 9 02-14-2007 08:32 PM
windows jamb sticks out past drywall tk3 Remodeling 2 11-28-2006 07:12 AM
Installing Windows after Drywall??? jeepwillies Building & Construction 9 11-22-2006 11:30 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
