Windows Wont Fit- Any Ideas? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 10:53 PM   #1
windows wont fit- any ideas?
Ok - I have 3 windows that I am putting in. They are 14 1/2" wide. I cut the first hole and it will fit snuggly into place and I think I'm off to the races! Great day ahead! @@$%^%%$@#%^
So, I cut the holes for the 2 remaining windows (drywall only at this point) and low and behold if there isn't a beam being supported by 4 2x6 studs making a cradle. First question - Can I remove a section of the 2x6 on the right side and put in a 1x6 then the window frame will make up the other inch when secured. Is that ok?
Next question is the 3rd window won't fit either. It is almost a whole inch off. So, can I take a sledge to it with the 2x6 brace that I will be installing under the window anyway. Should it move an inch in either direction this way without damaging anything?
hammer is offline   Reply With Quote
Old 03-11-2008, 06:23 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,632
That sounds like a Load Carrying beam,.... So,.. Nope,.. Don't do it.....
No......
Bondo is online now   Reply With Quote
Old 03-11-2008, 06:51 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As stated: No...and No....are the answers...
- Build Well -
Old 03-11-2008, 08:29 AM   #4
What would be my best option? Removing 1/2" off both studs? Or can I remove a whole inch from one side. This is an exterior wall so it will be load bearing for sure.
The beam holds up a small overhang for the front porch. kind of a wrap around type. It is not in the middle of the house.
Old 03-11-2008, 08:37 AM   #5
Bondo's Avatar
I would think Smaller Windows, or placing them where they Don't interfere with the Structure of the house.....
Old 03-11-2008, 08:50 AM   #6
This is the smallest they can make the windows. This is also where they have to go. no choice in that. Am I looking at doing a little bit of work here for an inch?
Old 03-11-2008, 09:25 AM   #7
Rewards Points: 5,336
There are two choices. You can do it correctly or you can do it stupidly. Correctly, is you reframe the openings to fit the windows. Stupidly is everything else, because it compromises the structure of the house.
You seem to be opening holes in drywall and hoping there is a framework for window installation. It doesn't work like that. If you're installing windows in a new location they need to be framed out with the appropriate structure. They need to be weatherproofed on the exterior and trimed in the interior. All the new drywall will need to be primed and painted. Maybe you can get away with just painting the one wall, but more then likely the whole room will need to be done.
Ron
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
terrible windows mt232 General DIY Discussions 10 12-28-2008 05:37 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
