Windows Sweating On The Inside - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 11:25 PM   #1
Windows sweating on the inside
I wasn't sure if this fits in here or not but I'll give it a try. I live in an old farm house (50-75 yrs old) with rough cut 2X4 walls. Approximately 6-8 years ago, I pulled all the siding off, put in some windows, moved some, etc, etc.. The walls were covered with 1" pine boards throughout the house originally. Some did need to be replaced and they were as needed. When I put everything back together, I put 1" styrofoam on the exterior walls and then my siding. For some time now, I live in Maine, we have been having quite a time with the bottom 1-2" of most of our windows building condensation during the winter. At times, it gets so bad that it builds and drops down onto the trim and pools (at times- not sure if there is a pattern here or not). It has been quite cold lately but I'm at a loss why this is happening. I've been told that the house it too tight. Is this a possibility? I'm looking for ideas and solutions. Thanks,
Dale
DaleB is offline   Reply With Quote
Old 12-22-2009, 12:29 AM   #2
Our house was built in 1995 and we have the same problem. The house does not have house wrap, but I've heard the same explanation - the house is too tight. Our builder told us to run the furnace fan all winter to keep moisture from condensing on the windows. We did that, but moisture still condensed. We are now in the process of replacing most of the window sashes because they are rotting. Not a cheap project.
In our case, only the glider / slider windows are rotting. The casement windows are still ok. Moisture condenses on cool surfaces, so my guess is that these windows are more leaky than the casements. Interestingly, the stationary half of the sliders are worse than the operating half. Not sure why that is.
We just replaced our furnace and central air. The contractor said that an air exchanger / dehumidifier is needed to eliminate the condensation problem on the windows. That solution fits the theory that the house is too tight.
Until you "solve" the problem - maintain your window sashes. Try to keep them dry. Refinish them each spring so they don't rot - new paint or sealant. If your windows are sealed (natural wood), consider an exterior sealant.
Fleener is offline   Reply With Quote
Old 12-22-2009, 06:04 AM   #3
Condensation on the inside of high efficiency glass is an indication of high humidity inside the house. Sources include, lots of house plants, no fan in showers, cooking, tight house. In the winter, 50% is high. Do you have a humidity gauge?? It sounds like you tightened up the house well when you remodeled. What kind of insulation in the walls, vapor barrier?? You may need a whole house air exchanger.
Old 12-22-2009, 08:13 AM   #4
ccarlisle's Avatar
We just had a post and a long thread, just a few days ago, on that; read that for a full explanation of why humidity condenses on cold windows. But the short answer is that there is too much moisture in the air and/or the ventilation insufficient to dissipate it. This brings up the question of the temperature at the window...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-22-2009, 09:37 AM   #5
Rewards Points: 582
I've got an old cottage with single glazed windows, which, living in a damp climate are always wet. It's no problem, the wife goes round them with a J cloth all day. It's a cheap type of dehumidifier.
stuart45 is offline   Reply With Quote
Old 12-22-2009, 01:21 PM   #6
Newbie Bill
Rewards Points: 522
Here is the thread Ccarlisle was talking about. Very informative.
Moisture on windows
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
Replacing windows from the inside RosenKen Remodeling 3 08-06-2009 12:27 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
