Windows Nailing Fins - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 05:04 AM   #1
Question
Hi I am building a new home and have purchased second hand casement alunium windows which I am installing. Can anyone recommend the best way of going about this as the nailing fins are non existing?
Any HELP or ADVICE would be greatly appreciated.
Cheers Kain
Kain Dillon is offline   Reply With Quote
Old 06-16-2008, 06:06 AM   #2
check the window you should have screw holes around the inside of it that how you attach it
clasact is offline   Reply With Quote
Old 06-16-2008, 09:31 AM   #3
47_47's Avatar
Rewards Points: 74
Why are you putting second hand windows in a new home?
47_47 is online now   Reply With Quote
Old 06-16-2008, 02:46 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
This was my thought exactly. What are the energy ratings on those older aluminum windows? What you think you are saving initially, may end up costing you even more, in the long run (with glazing heat loss).
Also, replacement windows are for installing in existing window frames. If it's a new construction home, you want to use new construction windows with nailing fins (with good Low-e ratings).
- Build Well -
Tags
construction , windows
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
windows mt232 Building & Construction 5 04-09-2007 04:26 PM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
