Windows? (Good Or Bad?) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2007, 05:34 AM   #1
Rewards Points: 552
Windows? (Good or bad?)
In today's new homes are having a lot of windows a good thing or bad, when it comes to energy efficiency?
kcrossley2 is offline   Reply With Quote
Old 01-21-2007, 09:14 AM   #2
What part of the country will the house be built in? (hot area or colder area)
Most energy efficient windows only have about an R-3 insulation value. Most walls of a house could have from R-13 to R-19+.
How many windows will face south?
redline is offline   Reply With Quote
Old 01-21-2007, 09:38 AM   #3
Rewards Points: 552
Wow! That's a HUGE difference.
Southern VA
House faces south
Windows are on pretty much every side
Old 01-21-2007, 02:52 PM   #4
Facing the house south in a colder climate will give you heat gain from the sun. Locate more windows on the south side and less on the other sides to lower heat lose thru the windows.
A southern facing house in warmer climates means that you will get more unwanted heat gain from the sun resulting in more A/C use. Locate more windows in the sides that doesn't face the sun.
terrible windows mt232 General DIY Discussions 10 12-28-2008 06:37 AM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
Caulk Windows eric s General DIY Discussions 2 11-26-2006 09:45 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
