Windows And Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2011, 11:33 AM   #1
windows and doors
Does windows and doors needs fine craftsmanship and high quality materials?
mariamario is offline   Reply With Quote
Old 11-24-2011, 12:00 PM   #2
Rewards Points: 5,336
I think it "doos".
Ron
B. Franklin 1759
Old 11-24-2011, 12:17 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
Tom Struble is offline   Reply With Quote
Old 11-24-2011, 12:19 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 686
Send a message via Skype™ to AndyGump
No.
The rougher and cheaper the better.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
woodworkbykirk (11-24-2011)
Old 11-24-2011, 04:33 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
yes, better constructed windows and doors will not only provide better energy efficiency but will last longer, provide greater security and operate better
ive trimmed out homes where the homeowner cheaped out on brand new windows... just before i start to install window casing i always check the operation of the window to see if it needs to be tweaked before closing things up. on 3 of the windows in teh house, the sashes literally fell out of the frame not good. a well made window will operate smoothly and have tight weatherstripping to eliminate leaks and drafts
woodworkbykirk is offline   Reply With Quote
Tags
home vinyl windows , windows and doors
New windows and doors for remodeling Andee77 Building & Construction 2 10-10-2011 02:27 PM
Aligning windows and doors papageek Building & Construction 1 11-04-2010 09:42 AM
Help! Mismatched Trim, Doors, Windows - Paint them All??? Snowy334 Interior Decorating 12 06-30-2009 02:26 PM
Front Home Doors Change or Cut 4 Windows Canis19 Carpentry 13 04-13-2009 06:19 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
