Old 04-07-2010, 01:40 AM   #1
Windows in a corner, off a floor
I am adding on a single story addition and have a question. How close can a window be to the corner? Is there a code, or even a best practice out there?
Second, how far off the floor can they be. I have heard 18" and anything lower must be tempered. Is this universal?
thanks.
bmt1970 is offline   Reply With Quote
Old 04-07-2010, 07:20 AM   #2
I have seen windows that wrap around a corner, but that takes some pretty heavy cantilever support.
IRC R613 deals with windows. Must be 24" above floor level, or if below 24", must be fixed glass or with no opening larger than 4". R308.4 states that glass below 24" must be tempered.
Localities alter the code to suit their requirements, check yours.
Old 04-07-2010, 11:35 AM   #3
jlhaslip's Avatar
Tempered glass isn't expensive.
I just priced a window a a double pane unit was $44 using standard glass, $57 using tempered on both sides.
Unit was about 24 " x 24 ".
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 04-07-2010, 10:30 PM   #4
Moderator
Look on your approved plans. If a continuous sheathed wall, the minimum required panel at the corner is stated by your building department. OR it has to be engineered to tie the header ( mechanical connection) to the main run to transmit the wind/seismic forces at the corner loads to the earth. Shear flow is important to a wall.
Be safe, Gary
Clothes taking longer to dry?
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 09:59 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 09:07 AM
