Window Well Pics / Project - HELP - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 04:03 PM   #1
Rewards Points: 892
Window Well pics / project - HELP
I posted this in the masonry forum but figured I could repost here since it gets more views.
I'm in AZ and there's no frost in Phoenix. I'm one of the rare homeowners who has a home in the state of AZ! It was built in 1993. The basement is about 9' deep.
I have only two basement window wells in my home but four bedrooms downstairs. Two rooms have no windows. I plan to build two more. My two existing wells are made from 8" concrete filled block as is my entire basement foundation. This is my current window well. I don't think it's big enough for current code:
The first room I'm putting the window well in actually has a door that leads to a walk in closet with an escape ladder. Very weird. No window. This walk in closet is built just like my window wells. It's concrete filled 8" block with a concrete slab. No clue how thick it is. See below:
It's a long story but what I'm going to do is lay block INSIDE the walk in closet so I essentially have the same dimensions as my existing window well. About 3.5 feet by 3.5 feet. The remainder of the walk in closet will be back filled in with dirt and I will be laying a concrete patio above it. Like I said, it's a long story - the walk in closet doesn't have a roof!!!!! But a make shift particle board deck. The house wasn't extended above the walk in closet when the house was built! This is above that walk in closet:
Can I lay block directly on this concrete slab in the walk in closet and anchor in the blocks to the existing blocks as I go for support or do I need to hammer out a footing? again, the length of each new wall inside the closet would be 3.5 - 4 feet.
Daugela is offline   Reply With Quote
Old 08-25-2013, 09:49 PM   #2
Msradell's Avatar
Rewards Points: 172
Why not just set up a form and pour a ceiling for the closet area when you pour the new slab? Never getting too much storage space to why takes them away? That would certainly be much easier than building the wall and backfilling.
Msradell is offline   Reply With Quote
Old 08-25-2013, 09:53 PM   #3
Rewards Points: 892
I thought about that but have been told concrete ceilings like that would cause condensation and moisture problems under it in environments like mine - Arizona. No?
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Window seat between two built-ins under low window questions. noone Carpentry 27 02-16-2012 07:41 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
Gap in Interior Window Frame/Wall from Remodel. How to fix? Pic's Included. cbj8585 Building & Construction 5 10-19-2009 12:11 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
