Window Well Filling Up And Water Is Now Coming In - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 09:51 AM   #1
Window well filling up and water is now coming in
When it rain th window well fils up now the water has started o cone in what can I do to stop this from happening
terese is offline   Reply With Quote
Old 05-15-2011, 02:27 PM   #2
Ironlight's Avatar
I suspect that if this is a new problem that the issue has to do with more water getting in than usual rather than the water not draining properly.
So logically there is some condition that is causing more water to enter the window well. I would inspect the condition of your gutters and downspouts in that area and make sure that they are functioning properly. Do the downspouts exit above ground or do they enter the ground and drain underground? If they exit above ground is the water being properly directed away from the house? If underground, there may be a blockage. Also check to see if the ground is graded properly so that water runs away from the house foundation.
Pictures of the window well and the area around it would be hugely helpful.
Ironlight is offline   Reply With Quote
Old 05-15-2011, 04:50 PM   #3
Rewards Points: 5,336
Discover the issue that's causing it. Since you live there, this should be easy. Next time it rains, go outside and look around.
Is water pooling next to the house?
-then regrade the area.
Is water over flowing the gutters?
- have the gutters cleaned and put covers on them
Are the leaders too short and letting water get close to the house?
-extend the leaders so they're at least 3 feet from the house
-regrade the area.
Ron
Old 05-15-2011, 05:04 PM   #4
Rewards Points: 1,596
On my new home, my builder wanted to drill a hole in the foundation wall, insert a PVC pipe, bring it into the cellar's sump pit and pump it out. No, I don't think so.
bob22 is online now   Reply With Quote
Old 05-15-2011, 09:41 PM   #5
we fixed a few window well water problems like that.
In our case the houses had downspout drains around the perimeter of the house. we dug down and cut into it and added a drain in the window well and that took care of it. we also put a couple of feet of gravel in there also to let the water drain out easier.
Old 05-16-2011, 05:16 AM   #6
Rewards Points: 4,656
window wells are a large pita to fix as, usually, they're below grade & its not often you can persuade water to run uphill bob, that's a std fix particularly if you already have an interior system including pump,,, often regrading can resolve the issue particularly if a window well cover is installed - good luck !
Old 05-16-2011, 06:28 PM   #7
I regraded, diverted downspouts 10' away and put a drain line in the window well to divert 10' away as well (belts and suspenders). No more window well filling up with water now and no hole in my foundation wall purposely letting water inside.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Window Leak: Flashing or Window? lverma Building & Construction 16 08-31-2010 12:46 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 07:40 PM
