Window Tube Balance - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 02:49 PM   #1
jelly's Avatar
Rewards Points: 330
window tube balance
Are these easy to replace?
Entire window could probably be replaced but looking for a temp fix.
Any brick and mortar stores sell these?
jelly is online now   Reply With Quote
Old 06-05-2008, 03:12 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
You're talking about a tube with a spiral coming out of it?
Old 06-05-2008, 04:16 PM   #3
jelly's Avatar
Rewards Points: 330
Yes... can they be adjusted?
I have 7 double hungs and each has 4 tubes @ $10.00 each to replace is more money than I wanted to spend.
I searched this forum but surprisingly did not find a topic on this. Thanks
Old 06-05-2008, 08:08 PM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
Yes they can.
once you secure the balance to the bottom of the sash turn the outer casing until the sash stays up. then secure the top of the balance to the window jamb same location as the old one.
Old 06-05-2008, 08:26 PM   #5
jelly's Avatar
Rewards Points: 330
hi buletbob, can i adjust my old window balances so my windows wont fall or are you referring to adjusting new ones if I were to get them.
Old 06-05-2008, 08:45 PM   #6
buletbob's Avatar
YES
Most of the times the spring breaks in side the guide keeper.or the guide it self fails. which means you will have to change the balance. you can try to tighten the tension by removing the nail at the top of the balance and turn it a few times until the window stays put. if you here the spring unwind then see if the spring came unfastened from the bottom of the sash. if so re secure to sash. if it still unwinds then its time to replace. BOB
Old 06-06-2008, 05:52 AM   #7
I haven't worked on any of these in years but they were called "Unique Sash Balance", and they are adjusted like bulet said. I'm not sure if they are still made. I remember they were a pain to adjust.
Old 10-04-2008, 12:50 PM   #8
Originally Posted by buletbob View Post
YES
Bob
Know of anyone on LI who would do these type of repairs? Have a few windows where spring needs to be replaced.
Rob
8inline is offline   Reply With Quote
Old 10-04-2008, 05:04 PM   #9
buletbob's Avatar
Originally Posted by 8inline View Post
Bob
Rob
Me!
Old 10-05-2008, 03:54 PM   #10
let me know if you are interested in doing it and how to get in touch with you - my wife also wants someone to build a window seat, saw something in your pictures that she liked.
Old 10-05-2008, 07:06 PM   #11
buletbob's Avatar
I'll PM you.
Old 10-12-2008, 07:32 PM   #12
Windowpartsguy
Everybody else in the world uses a "spiral balance adjustment tool". They cost about $10 retail. Most manufactures give them to their better customers.
Anyone who has done this more than once would never think of not using one. You do not unscrew the top of balance at all - you just grab the bottom tip (shown in your pic) with the "grabbers", disconnect and twist away to your hearts content. It is about 10x faster, and user friendly.
Also you don't want to grab those old tubes with your hands. When they get funky they leak.
I wanted to attatch this pdf from Jeld-Wen but it is too big a file.
www.jeld-wen.com/_pdf/resources/howto/swd009.pdf
or just Google "spiral balance tool" they have been around forever.
Ed
Macattac is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 06:19 AM
Shower in Window jchri66 Remodeling 1 05-27-2008 12:50 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 04:15 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
