Old 03-07-2009, 11:34 PM   #1
window tape??
Has anyone heard of a tape that window installers use instead of the caulk??? If you know what Im talking about, what method is better? Im not sure what the window guy was talking about. (This tape is not the flashing tape, It sounds like double sided stuff and he stating that its better the caulk?)
fricandfrac is offline   Reply With Quote
Old 03-08-2009, 08:15 AM   #2
window tape??
Window installer for 24 yrs, have no clue what you are talking about, unless it is flashing tape. That goes over the nailing fins on new construction windows, to seal against water and drafts.
Old 03-08-2009, 09:34 AM   #3
window tape??
Butyl tape I think?
Josh Jaros Remodeling in The Woodlands, Texas
jaros bros. is offline   Reply With Quote
Old 03-08-2009, 09:54 AM   #4
Pro Slate Roofer
tinner666's Avatar
window tape??
I heard of it recently. After the window wrap, then after the metal flashing, it goes between the metal and the window. Then, after nailing off the fin, the last tape covers the fin.
Frank
tinner666 is offline   Reply With Quote
Old 03-08-2009, 02:45 PM   #5
Tom Struble's Avatar
window tape??
its a self adhesive vinyl trim extender you still need to caulk the window
RWD trim extender
http://rwdextendertrim.com/portability.html
Tom Struble is offline   Reply With Quote
Old 03-09-2009, 12:54 AM   #6
window tape??
Is this it? http://solutions.3m.com/wps/portal/3M/en_US/VHB/Tapes/
Mop in Hand is offline   Reply With Quote
Old 03-10-2009, 08:16 PM   #7
window tape??
Thanks,This is sure making me lose trust in my "window guy" he did however say he would use caulk if I wanted him to. Ill try and make sure he does.
Old 03-10-2009, 10:13 PM   #8
window tape??
i would caulk the window first then put the trim over the caulk,this way its sealed and the caulk is protected
dont lose faith in him it looks like he wants to give you a better job
Old 03-17-2009, 02:29 AM   #9
window tape??
Thanks tom...That makes sense. I know "he" said it doesn't caulk with the tape but if I mention the way you stated I think he would do what I ask for....hopefully!
Old 03-17-2009, 02:32 AM   #10
window tape??
Thanks for the web sites...I totally dont understand yet, but he's the "expert" I guess?
Old 03-17-2009, 02:29 PM   #11
Pro Slate Roofer
tinner666's Avatar
window tape??
Does this link help you with the uses of tape and sealing? http://www.albertsroofing.com/Window%20Flashing.htm
Frank
Old 02-11-2011, 09:06 AM   #12
window tape??
It's 2 sided tape that installers use instead of caulk. I'm sitting in front of one of those windows now and the shade is flapping in the breeze on a 6 degree day. I have double paned sealed windows too. Does anybody have any suggestions about caulking it? I work at a school and have a couple thousand to do.
Randal is offline   Reply With Quote
Shrink film window insulation, no kit EscarHolmez General Discussion 3 12-28-2008 01:05 PM
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
