Window Symmetry - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 09:14 AM   #1
Window Symmetry
Need some input. I've replaced the 1950's vertical windows in my house to get more of a colonial look (5 upper story/4 lower) and am trying to figure out what to about the middle window on the upper story. It doesn't exist yet but our portico comes up too high to fit in the same 30x56 windows that are already in (too many changes on the fly...). I have a 30x48 I was going to use but when the contractor placed it, I didn't like how it threw off the symmetry. Has anyone used windows that have a larger top "half" than the bottom. I'm thinking if I get a 50"-52" window made with the top half the same size as the installed windows, I will maintain the symmetry and the smaller bottom "half" of the window will be partially hidden by the portico anyways. Thoughts? I've attached what it looks like with the 48" window held
in place.
craleo is offline   Reply With Quote
Old 01-07-2009, 09:32 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
how about a round,oval or octagon?Is it a bedroom window with egress concerns?
Tom Struble is offline   Reply With Quote
Old 01-07-2009, 09:56 AM   #3
No egress issues with this one. I'm trying to stay with the same style across the upper story. I'm not a big fan of the octagon/round windows.
Old 01-07-2009, 10:11 AM   #4
bradnailer's Avatar
I'd have suggested and octogon window as well but never mind.
Probably when you get the exterior veneer on, it will look just fine the way it is.
bradnailer is offline   Reply With Quote
Old 01-07-2009, 10:16 AM   #5
ive never seen a widow with a smaller lower sash but they do make them with a smaller upper sash they call them cottage style the window manufacture will probably make you anything you want
Old 01-07-2009, 10:24 AM   #6
Learning by Doing
Leah Frances's Avatar
I would go with the regular sized top half and the smaller bottom half - keeping the top line consistent.
In the end, I think it is the little oddities or non-conformities in houses that make them homes.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-07-2009, 10:45 AM   #7
cool
Old 01-07-2009, 10:52 AM   #8
The top line symmetry is what I think will be key but then again, I'm flying by the seat of my pants in terms of design!
Old 01-07-2009, 10:55 AM   #9
are you installing shutters?
they might emphasize or conceal the difference
Old 01-07-2009, 10:56 AM   #10
Also, my thinking is that the middle window will be 52" vs. the others at 56"
So if I make the top equal, the bottom is only going to be 4" shorter than the other window bottom halves (20" vs. 24" of actual glass height). I have a feeling it wouldn't be that obvious (especially with the portico).
Old 01-07-2009, 10:57 AM   #11
No shutters. I'm using 5" Azek trim surrounds.
Old 01-07-2009, 11:16 AM   #12
very nice
Old 01-08-2009, 12:26 PM   #13
12lt Csmt
A 12 lite casement may work well, the grids may then be a little closer to the surroundings. Honestly, the house as shown with the smaller DH in the center doesn't bother me a bit because it is centered and above the door AND...
it gives an illusion of depth, like it is on a wall closer to the street.
Last edited by dee dee; 01-08-2009 at 12:30 PM. Reason: depth illusion that it is jutting out
dee dee is offline   Reply With Quote
Old 01-09-2009, 09:45 AM   #14
any chance of getting another picture without the workers butt in the way.I would like to see just how far the window cones down and how it matches up with the rest it a little hard to tell with him in the way Thanks
clasact is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
Window Install? sod Building & Construction 3 10-26-2008 08:02 AM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
