Old 07-17-2011, 10:53 PM   #1
Window sill recess 4 a brick wall
Hi,
I am about to frame and tile the interior window sill and recess. I just wanted to check to see if anyone had any tips, witticisms, or constructive criticisms.
My plan: As you can see in the pics, I have a window in a brick wall with a metal-framed interior wall. After foam insulation, I was gonna put 1/4 inch wood around the window to connect the brick and the metal framing. Slope the bottom piece so that water doesn't go towards the window. I want tile all around the recess and to border the window. So, on the wood, I would put 1/4 inch hardibacker, tape and mortar the seams, then Redguard on top.
Note that half of the window (and wall) will be tiled for my shower/tub and the other half will be painted . Don't worry. The shower stream will be in the center of the tub inside of a cylindrical shower curtain NOT streaming towards the wall with the window.
Peace,
Red
Window sill recess 4 a brick wall-003.jpg   Window sill recess 4 a brick wall-034.jpg   Window sill recess 4 a brick wall-035.jpg   Window sill recess 4 a brick wall-036.jpg
RedBear is offline   Reply With Quote
Moisture concerns building against a brick wall (PICTURES) aluminum13 Building & Construction 8 05-17-2011 09:07 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Garage brick wall repair TANME General Discussion 2 02-04-2010 07:19 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 08:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
