Old 08-06-2007, 12:48 PM   #1
Window Sill flashing?
When installing a new construction window, do you use flashing tape for the sill or a pre bent metal flashing?
sandyman720 is offline   Reply With Quote
Old 08-06-2007, 04:30 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
If it is a new construction window then it comes with a nailing flange. No ''metal'' flashing is needed.
As far as what to use over the nailing flange, we use either: Water and Ice shield membrane, flashing tape or Tyvek tape.
- Build Well -
Old 08-06-2007, 06:26 PM   #3
zel
Send a message via AIM to zel
Gracie water and ice shield tape. We used it on the whole rough opening frame.
zel is offline   Reply With Quote
Old 08-06-2007, 06:46 PM   #4
(FWIW: We only use it on the lower opening area and up 6" on the sides. Water travels and sits downward)
- Build Well -
Old 08-06-2007, 06:51 PM   #5
zel
I hear ya. My Dad first found out about the product on a show called "American Builder" which I think is a local show in Comcast. They had a rep from Gracie on the show and the rep was showing off the product. He covered the whole window opening. My Dad insisted on doing it exactly as the rep was doing it. In my case, it was only 3 windows, so not a big (or expensive) deal. He likes to overkill everything.
Old 08-06-2007, 10:13 PM   #6
no big deal, but the company is "Grace". You can get their flashing at Home Depot and Lowes. (I work for them ;-)
hydepark is offline   Reply With Quote
Old 08-06-2007, 10:24 PM   #7
zel
Doh! Sorry! In any event, we were real happy with the product. Especially considering the original windows had no protection on the sills, and you could clearly see they had gotten wet over the years.
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window Well Installation Bill46 General Discussion 1 04-03-2007 05:49 PM
Replacing the Sill on a Double hung Window Marshall Building & Construction 2 03-30-2007 12:18 AM
window flashing RickT Carpentry 6 10-26-2006 08:29 PM
