Window Screen Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 01:25 PM   #1
window screen repair
How do you replace the screen on andersen sliding door panels?
Rgedson is offline   Reply With Quote
Old 07-25-2011, 04:45 PM   #2
Rewards Points: 5,336
Pull out the splines and replace the screen. Only difference might be the spline material. The splines might be metal.
Ron
B. Franklin 1759
Old 07-25-2011, 07:35 PM   #3
One thing that I would watch is that if you try to pull the material to tight to the horizontal edges it will bow the door in. I always use something to maintain the width of the door when you attach the material and roll the spline back into the tracks.
Travlnman is offline   Reply With Quote
Old 07-25-2011, 07:36 PM   #4
Sorry boout that, I meant the VERTICAL edges! The long ones.
Old 09-29-2011, 10:17 PM   #5
Rewards Points: 32
Wish I would have read that about 6 hours ago. urrrghhh off to the store to get another roll of screen and "unbow" my new door
reggae5 is online now   Reply With Quote
Transom window repair options (with pictures) barlav Windows and Doors 4 06-14-2011 07:31 AM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
screen for window aclerok Building & Construction 1 10-28-2006 08:26 PM
