Window Return In Concrete Block House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 02:02 PM   #1
window return in concrete block house
I'm renovating a concrete block house and the walls have been stripped of the old plaster. The window returns are pretty coarse and rough - not smoothe at all. I'm trying to figure out how best to finish the window returns so that they are smoothe. Complicating things is that the existing aluminum windows have a very narrow frame (maybe 1/2") so any solution has to take this into account. If I nail a furring strip to the inside of the return and fasten 1/2" drywall to that it will completely cover the window frame.
I have no experience with plaster so I'm leary of trying to re-plaster the window returns back to the way they were. I thought about glueing green board to the block but I know there needs to be an air space between the two materials.
What's the best material to use to smoothe out and finish the returns? It must be able to stick to concrete block
bmancanfly is offline   Reply With Quote
Old 05-17-2009, 05:38 PM   #2
Drywall compound is fairly easy to work with and sticks to about any thing.
hayewe farm is offline   Reply With Quote
Old 05-18-2009, 07:32 AM   #3
someone told me that because of the moisure that might be present in the block that drywall compound wouldn't be a good idea.
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 10:57 AM
1940s house in mid TN, block walls, no insulation kscudebec Building & Construction 2 01-15-2009 04:22 PM
Cold Air Return in an Old House DaleB HVAC 2 01-09-2009 10:20 AM
Glass block window position?? justdon Remodeling 4 09-28-2008 06:29 AM
Concrete Block under the Front Door Robinjail Building & Construction 1 06-27-2006 10:04 PM
