Window Replacement And Trim - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 08:39 AM   #1
Window Replacement and Trim
I'm replacing an old window with a rotten sill with a full frame Andersen new construction window. I'm using full frame instead of replacement windows because the new sill comes attached. The outside of the house is Vinyl and the trim around the window is covered with aluminum. Once installed I was going to trim it out with 5/4 primed pine and not recover it with aluminum. It won't look like the rest of the window trim on the house that is covered in aluminum but I think it will look better.
Anyone have any better solutions for the trim or think the primed pine trim could cause any problems with the vinyl siding?
Picture attached.
Red Truck is offline   Reply With Quote
Old 02-11-2010, 08:46 AM   #2
DIY staff
Rewards Points: 7,174
I always use Azek--White pvc trim boards.
No paint needed--can't rot--easy to work with--a bit pricey--but when you're done you're done.
---Mike---
Old 02-11-2010, 08:51 AM   #3
Thanks Mike. Can I cut the Azek with a regular blade?
Old 02-11-2010, 10:13 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Azek is very easy to cut, and its a good recommendation. There isnt any issue in doing what you suggest, however make sure that you get the opening and the new window flashed properly. Some siding removal will likely be necessary for this.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Interior stop trim after installing replacement windows not fitting correctly DyerWolf Carpentry 10 11-26-2009 09:53 AM
Old aluminum window replacement. nancwilt General DIY Discussions 1 09-10-2009 06:02 AM
Replacing Inside Window Trim lensgaga Remodeling 3 09-20-2008 06:46 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-13-2005 11:59 PM
