-   -   Window Replacement and Trim (http://www.diychatroom.com/f19/window-replacement-trim-64142/)
Red Truck 02-11-2010 09:39 AM
1 Attachment(s)
I'm replacing an old window with a rotten sill with a full frame Andersen new construction window. I'm using full frame instead of replacement windows because the new sill comes attached. The outside of the house is Vinyl and the trim around the window is covered with aluminum. Once installed I was going to trim it out with 5/4 primed pine and not recover it with aluminum. It won't look like the rest of the window trim on the house that is covered in aluminum but I think it will look better.
Anyone have any better solutions for the trim or think the primed pine trim could cause any problems with the vinyl siding?
Picture attached.
oh'mike 02-11-2010 09:46 AM
I always use Azek--White pvc trim boards.
No paint needed--can't rot--easy to work with--a bit pricey--but when you're done you're done.
---Mike---
Red Truck 02-11-2010 09:51 AM
Thanks Mike. Can I cut the Azek with a regular blade?
HomeSealed 02-11-2010 11:13 AM
Azek is very easy to cut, and its a good recommendation. There isnt any issue in doing what you suggest, however make sure that you get the opening and the new window flashed properly. Some siding removal will likely be necessary for this.
